Loader Tilt Problem
   / Loader Tilt Problem #1
Latimer1776
Mahindra 2638
I've done some basic searching, and I've looked this issue up before to no avail, so hopefully someone can give me the right direction to look.
I have a Mahindra 2638 with a front loader. The front loader works fine when I have my bucket or grapple on (though I need to ensure the arms are level), but when I'm connecting/disconnecting the issue pops up. When the front is not under load, the quick attach will not tilt forward. At one point it would move a few inches back and forth, but now it's stuck curled back as far as it goes. This makes it difficult to switch from bucket to grapple and back, as I have to tilt or lift the implement to put it on the quick attach. It works fine under load/with a bucket, but not otherwise.
Any clues what this might be? I have my 50 hour service coming up, so I might have the guys take a look at it, but would prefer to walk in the door with a little knowledge. Thanks!
   / Loader Tilt Problem #2
Let's try something simple. With the engine off, move the joystick around to release any pressure.
Then, disconnect each line and reconnect back again to make sure all lines are fully seated.
If the problem persists, it's something else going on.
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
