Loader Third Valve Function
   / Loader Third Valve Function #1
Millhaven, Ontario, Canada
Massey Ferguson 1532, Bolens G174
I am in the process of planning two projects for my tractor, one is a 4 in 1 bucket and a snowplow on the loader arms. Both of these will be built from scratch based on other models I have seen in real life and on other posts here. The first step is to get a third function somewhere on the loader to operate the rams of these tools. I have never had the oportunity to run this setup and was wondering which set of lines I should tie the third function into (Up/down or dump/curl)? Is there at standard? I am thinking it should be the dump/curl.
   / Loader Third Valve Function #2
From what I have read, most use the curl function. I believe the grapples, etc. are tied into the curl circuit. I don't have one so I can't say for sure, just from what I have read.
   / Loader Third Valve Function #3
I would find out what valve you have on your loader, who makes it. The see if it has a power beyond option and tap off there for a 3rd function. On my valve for example I can still have lift and curl with a electric 3rd function that puts a rocker switch on top of the loader control to activate the 3rd function, what ever that may be. Seem to be the best option to me..
Chris
   / Loader Third Valve Function #4
They are run off the curl/dump circuit............... but I'm with Diamond pilot. I'd recommend you run an electric solenoid valve for true third function instead of a diverter off the curl/dump. Theres lots of reading here on the subject, so you can make an informed decision on whats best for you.
   / Loader Third Valve Function #5
Marc:
There may be a terminology problem. "Third function" to most readers means a spool valve inserted in the power beyond circuit of the FEL valve. It is almost, but not quite, the same as if there were a third spool (and related handle) on the FEL valve body to control the plow, grapple, etc. Although the third function valve can be a simple manual single spool valve, it would require a separate lever to operate it and, for most of us, more hands than occur naturally. Therefore, most third function valves are electromagnetic; that is, they are operated with a switch on the FEL valve handle (joystick). The only disadvantage (if at all) is that the reasonably priced electromagnetic single spool directional control valves are not proportional; you flip the switch one way and the plow swivels left at full speed; you flip it the other way and the plow swivels right at full speed. Most people address this problem by using small (1/4") lines for the third function valve work circuit to slow down the fluid. For a few more dollars you can install adjustable flow control valves in the circuit, or for a very few dollars you can install fixed orifice flow restrictors in the lines to the plow.
The alternate approach is to install a diverter valve (also called a selector valve) in either the lift or the curl circuit of the fel (usually the curl circuit). The selector valve is electrically operated (it can be manual, but those are awkward when you shift back and forth a lot). In one position (usually the rest position), it connects the curl spool (and work ports) to the FEL bucket, so when you move the joystick left or right it curls or dumps the bucket. But when you push the button (installed on the joystick) to activate the selector valve, it shifts the curl work ports to the additional cylinders, say the plow. So when the button is held down, moving the joystick left angles the plow to the left and moving the joystick right angles the plow to the right. The advantage of the selector valve is that the proportional flow control of the jolystick is maintained for both the original curl function and the new plow function. You can swivel the plow fast or slow, as you choose.
The commonly stated objection to the selector valve is that you can't operate the curl and the new function at the same time. Whereas, with the third function, you can activate the third function while activating the curl (as long as the curl spool is not fully shifted; that would block all fluid flow to the downstream third function valve). But there are selector valves that allow you to select either function separately (curl or plow) or both functions at the same time (curl and plow). That is, if you select both functions the curl and plow for example are connected in parallel, much like the curl and lift circuits in most FEL's. It requires a slightly more complicated switch.
I use the selector valve because I like the proportional control of the added circuit and because with the grapple it is easier to pick up objects like rocks with the curl and grapple circuits in parallel. But I am in the minority; most readers, I think, prefer the third function valve. I am sure you will hear from them on the benefits of that method.
Good luck and send pictures.
   / Loader Third Valve Function #6
What FF wrote is EXACTLY the proper reply to your question Millhaven. I would only add to it by suggesting your search in the Hydraulics forum where these questions have been asked/answered 100's of times.
Some search terms include:
diverter
3rd function
remote
snowplow
grapple
wr long
markham
millonzi
tatro
I was planning to use the electric solenoid activated "selector valve" as Farmerford described and he seems to have answered my dilemna. I want to do exactly as he does...Divert the joystick dump/curl to operate either my plow or 4 in 1. I don't have the full manuals for my 1532 so I don't know what the hydraulic circuit is like but I can't even get a straight answer out of the dealer as to whether or not I have a power beyond circuit available. All they want to do is sell me the kit for $1000 that gives me all the pieces for a dual rear remote setup.
I have searched the forums and read many posts but was basically looking for which circuit to divert... Thought people may have regretted one or the other.
   / Loader Third Valve Function #8
Are you talking to the salesman or the mechanic in the shop. If the mechanic doesn't know, then he should not be working there.
As far as proportional movements go, the electric valve can be bumped in small amounts or held down longer. The smaller lines just give slower movement. The buttons on the switch should be momentary, and spring centered, otherwise, no movement will occur unless you touch the switch,
   / Loader Third Valve Function #9
I want to build in the electric operated valve, found one, but now I am looking to add the switch, does anybody know where you can find the switch with goes over the joystick handle to operate the third function?
Pete.
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2016 COTTRELL EZ5307XL CAR HAULER TRAILER (A52141)
2016 COTTRELL...
2005 International 4300 Heil S/A Dump Truck (A50323)
2005 International...
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
