Loader Loader stalls on L3710
   / Loader stalls on L3710 #1
Budira
Stewartstown, PA
L3710
I recently had my metal return line replaced and complete servicing at 1000 hours. Now the bucket stalls when I go to full throw on the up lever. Partial throw on the up works fine as all other movements of the bucket. I talked to a mechanic at the Kubota dealer and he told me the female coupler on the return line was malfunctioning and just replace it. After replacing all the quick disconnects, I revved up to about 2000 RPM and went full throw up on the bucket. I did it three times and each time I blew a different line. I replaced the lines a they blew. They were 10 years old, but looked OK.
Any suggestions where to look before I haul it back in for servicing?
   / Loader stalls on L3710 #2
Check your joy stick linkage & your control valve.. KennyV
Also ... when you are checking for a hydraulic problem, leave the engine at idle speeds... when it works properly at idle, it will work at higher RPM without putting a lot of extra strain on things when things are not right...
Thanks Kenny, I thought about checking the linkage,but then decided I might be bypassing the real problem. I watched your video of flow rate and pressure correlation. I was able to build a pressure checker, but not flow rate. I will look at the linkage in case it has worn or worked loose.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
