Loader Relief Valve Fatigue?
   / Loader Relief Valve Fatigue? #1
Maddog10
Western KY
Massey 1742
Is this an issue at all? Does frequently hitting the relief pressure and causing the relief valve to open lead to any future issues such as a drop in set pressure due to mechanical fatigue?
For clarity, this is not an issue I am experiencing at the moment. Just want to make sure I'm not setting myself up for issues down the road. I have a 2019 MF 1742 and have been cleaning up some of my parent's property lately. An area of the property had been taken over by about 20 locust trees that I cut down and haul to the burn pile using the grapple. Now that the trees are gone we are left with the stumps. Yesterday afternoon I decided to remove a few of them so I began to dig them out using the grapple. I would let the grapple dig in a little bit on each side of the stump to try and rip up the roots and eventually work my way underneath the stump so that I could roll it out. Keep in mind these aren't large stumps, mostly 3"-4" in diameter, but they are still plenty big that their root system overcomes the rollback force of my loader which would cause the relief valve to take over repeatedly until they were loosened up enough to remove.
I work slowly and am careful not to ram anything, jar anything, or put awkward forces onto the tractor or loader itself. I'm doing this as gently as possible because I know a FEL isn't necessarily designed for digging. I was just wondering if consistently popping the relief valve may lead to any future problems?
   / Loader Relief Valve Fatigue? #2
YouTube
Subsoiler may be better weapon on the small stumps. Popping relief valve increases oil temp - wouldn't worry about it unless it's a continuous operation.
This is an interesting video on FEL / Grapple use.
YouTube
   / Loader Relief Valve Fatigue? #3
I have seen reliefs fail. But they are usually old and been in service decades before they do. They have a spring inside that can break. On our man lifts we commonly activate the tool valve with out a tool to make the relief "pop" to get the oil up to operating temp faster. Especially if a customer has a complaint related to heat. B.
   / Loader Relief Valve Fatigue? #4
I have a 1991 round baler, bale count unknown. Mine was set to 3000 PSI and was popping at 1-1.5k. Figure the spring got weak from old age. Replaced a couple of years ago.....comment here just to show you that they can and will do what you suggest.
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
