Loader Question
   / Loader Question #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
How well do the Jinma tractors dig with loader? I will mainly use mine for moving brush, gravel, dirt, and snow. But I have a few places that I will want to level and dig. Thanks, Ash
   / Loader Question #2
Well traditionally loaders are best left for loose materials such as piled gravel, manuer, chips, snow and brush with a grapple/fork. Lots of stresses generated by those long lift arms and lots of potential for damage digging into the ground. That being said, I use mine occasionally to cut into high spots and relocate it to the low spots and it does that very well. I do have pretty soft sandy soil and I do this type work very slowly so as not to shock load the structure. I am also not using a Jinma loader on my 284 and have no experience with that loader. A toothbar on the bucket would help to break up the soil but I don't do it that often to warrant that type of modification.
Ground engagement is best left to a box grader or scraper(my next tractor build project). The 3PH structure on the tractor with it's shorter arms loaded in tension is better suited to the loads involved with pulling a ground breaking impliment. There is a good thread up in the "build it yourself" forum from a gentelman that just finished building a grader box. He shows some pics of the way his finished product performs on the ground.
   / Loader Question #3
I agree, its best if you don't try to dig with a FEL. Moving loose soil/gravel or brush with a bucket grapple is the way to go.
Also, if you have a Jinma 4x4 there is a very good chance you will break the front axle if you try to dig with the FEL in 4WD. Seems to be a fairly common problem. If you can't push it in 2WD with the FEL, then don't do it.
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
1987 Ford F-250 Wrecker Tow Truck (A51692)
1987 Ford F-250...
2005 Fella-Werke SM-320 (A50123)
2005 Fella-Werke...
2005 Kubota M105S (A50123)
2005 Kubota M105S...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
