Loader Question:
   / Loader Question: #1
FRIZ
Bronze Member
NW Indiana
John Deere 4720 Cab
Loader Question:
I am city slicker who bought 78 acres of land. And I am smart enough to know that I know nothing. But before I ask my loader question, let me give you some information:
The land is in the Midwest, mostly flat, a few slight elevations. Most of it is wooded, approximately 10 acres are meadow, which has not been mowed in years.
Three ponds: 1.5 acre, 1+ acre and 0.5 acre, all with trees and grass around them.
The house has also trees and grass around it.
Approximately 800 yards of gravel road.
Approximately 1 mile of hiking trail which will be expanded.
I have identified the following tasks for the loader:
Drag trees out for firewood
Lift heavy stuff and take it from A to B
Clean up work, i.e. branches, garbage
Maintain the 78 acres of land
I am planning to buy the following tractor.
John Deere 3720 with a 300CX loader
Now I have the following questions:
Bucket:
61in or 73in wide?
Heavy duty or not?
If heavy duty, with tooth bars or not?
Are Debris Grapple Bucket and Pallet Forks useful to maintain my 78 acres of land? Or am I wasting money?
If a good investment:
Debris Grapple Bucket:
61in or 73in wide?
Pallet Forks:
42in or 48in?
PLEASE help with constructive criticism and with your experiences.
Thank you,
Regards,
FRIZ
   / Loader Question: #2
These are my opinions and worth what you paid for them:)
When looking a loader attachmnets you need to keep in mind the lift capacity of the 300 loader. If you can lift 2500 lbs a 300 lb bucket is part of the lift capacity. For instance if you had a 300 lb bucket you could lift 2200 lbs of dirt. A 700 lb bucket you could only lift 1800 lbs of dirt.
I would get the 61" bucket handy around the house/yard. Tooth bar, would be nice to have but if you NEED it you need more tractor or different tool (read skidsteer or mini ex)
Grapple bucket, expensive tool and lots of cost for hydraulic hook ups. It would be very nice moving debris out of the woods. Once again the more weight in the bucket the less capacity for lift. Be sure to price the power beyond to work the clamp.
The pallet forks are possibly a subustitute for the grapple bucket. They would be handy for moving limbs and debris. Longer would be better, but adds weight.
Hope this helps
   / Loader Question: #3
I have a 4200, with a 420 loader, I use a 72" bucket for snow removal, and a 60" bucket for dirt work. The 60" has hooks welded to the top, and will be getting a tooth bar. I also have a set of forks that I use to maintain a couple miles of ATV trails, and when cutting brush and trees, I leave everything as long as I can and still be able to get down the trail. I use the forks as much as the buckets, if not more. I have also grabbed some pallets and use the forks to move allot of heavy or awkward pieces of equipment, concrete blocks, axles, engines and transmissions around my property. I say forks, and one bucket made for ripping stuff up and pulling and lifting, then a bigger bucket for snow and back dragging. Hope this made sense.
   / Loader Question: #4
I do similar tasks on my 300 acre wooded land. I am constantly maintaining roads and trails and doing general maintenance. In my opinion, a bucket is generally useless for this type of work. It is great for moving gravel, mulch or loose dirt, but does poorly at digging or scraping. A bucket on a small tractor just isn't the same as a bucket on a dozer. A toothbar helps a little but I don't use mine much. My bucket stays mostly on the floor of my barn collecting dust. But it is handy at times, so get a cheap medium duty bucket w/o a bar for that occasional use. (assuming you have a quick attach on your FEL, which hopefully is skid steer compatible, but that's another topic). What I do recommend is a 48" root grapple (such as a Markham) which is the most useful implement I have. To pick up limbs and debris, to move rocks, logs, up-root trees and brush, or even pick up most anything, it is FAR superior to a bucket for what you describe. It has a "thumb" for clutching whatever you want to pick up, whatever the shape, whereas a bucket just can't clutch things. A grapple bucket is an alternative but doesn't do either task (bucket vs. grapple) as well as each specific implement therefore is a costly compromise. Disadvantages of a grapple are the initial cost (yet doesn't cost much more than a decent bucket) and the extra hydraulic controls necessary. And it helps to have a quick attach style FEL. But it will do so much more that a bucket and will quickly become your favorite implement. A grapple on the front and a box blade on the rear is a combination that will do most every task around your property.
A fork also seems unwise. Unless you are moving pallets, or building materials such as lumber or plywood, you don't need it. A grapple will pick up any thing forks would and clutch it tighter. (except the above mentioned materials). For instance, sometimes when I do need my bucket to move piles of dirt, I will pick it up with my grapple and carry it to where I am working so that I will have both on hand to save a trip to the barn to change implements. The other day I picked up a 20 foot long 500lb. steel pipe with the grapple and transported it to a culvert site. Try that with a bucket!
Check out threads by Islandtractor, the grapple guru on TBN. Hope this helps!
   / Loader Question: #5
I will start out by saying that unless you plan on mowing your lawn with this tractor, I thing you need to look at a bigger tractor for 78 acres. Don't limit yourself to just JD either. There are several other tractor manufactures that make fine peices of equipment that might fit your budget better and get you into a machine better suited to your tasks. Mahindra, Kioti, Kubota, New Holland, Massey Ferguson, Montanna, just to name a few. If I had 78 acres I'd be looking at a kubota l4400, MX5100, Kioti DK45 or similar sized Tractor. Do Your research, All the manufactures list very detailed specs on the web.
A bit of advice when comparing specs of 3ph and loaders, not all are rated the same. Loaders are rated at bucket center, pivot pin, and 500mm forward. 3ph's are measured at ball ends, and 24" back. When comparing, make sure you compair apples to apples.
As for buckets, if you plan on using it a lot, and doing a lot of dirt work, I'd get a 61" heavy duty. Buckets take a beating, and the stronger the better. If you were just moving light stuff like mulch and pushing brush, the 72" would be better, but given the size of the tractor and the traction ability, a 61" would be better for the dirt work.
Everything else mentioned is just luxury. Grapples, grapple buckets, forks, tooth bars, etc. they make the job easier, but you can still do most anything with a regular bucket.
If you want pallet forks, I'd get the 42" ones. The lift capacity of the 300 loader is only like ~1200lbs at the bucket edge. 48" beyond that and they can't do much. If you got something that you cant fit on the 42" forks, you probabally cant lift it anyway.
   / Loader Question:
Thank you all for the education. Please keep it coming.
Regards,
FRIZ
   / Loader Question: #7
I think a 4320 to 4720 would b a better choice. This will handle a large variety of 6' equipment very well. Then go with the 400CX, 72" hd bucket, 48" rail pallet forks, weighted tires, telescopic draft links, 6' box blade, MX6 rotary cutter and add the rest as you figure it out.
Steve
   / Loader Question: #8
Loader Question:
Bucket:
61in or 73in wide?
Heavy duty or not?
61in or 73in wide?
Pallet Forks:
42in or 48in?
Thank you,
Regards,
FRIZ
How big is your yard that you will mow regularly?
My guy feel is that the 3720 might be too small for the larger work you want to do.
I would not do the 73" bucket - too much for your rig unless you are moving very light material.
48" pallet forks - there are a couple options there.
I have a grapple bucket and it totally rocks.
How big a mower are you considering (shredder wise, finishing mower, ?)
10 acres - can mow fine with 6' shredder.
Consider a landscape rake for the road - box blade for the rough stuff.
I would think you should consider a zero turn mower for around the house stuff and tighter stuff - finishing mower.
A larger tractor the other stuff. Moving trees around is not trivial. You can turn a tractor over in a hurry. Heavier is better for sure. You will want to add weight to a 3720 tractor to make it safe.
We bought a place and cleared a bunch of trees. I had a 4720 with a 400x loader. It turned out to be a tad weak at times. I added a 5525 with a 542 loader with the grapple bucket and it is much better.
You asked about teeth for your bucket - you want it. They go on and off easily I suspect you will never take it off once you have it.
For sure - get the heavy duty bucket - but not too wide.
Get extendable links.
Do you ever think you will need a higher HP tractor?
Do you plan on baling hay?
Do you plan on running a 15' batwing mower?
Do you plan on adding a backhoe?
78 acres plus a house - making one tractor do it all can be tough.
D.
   / Loader Question: #9
Hope this helps
Grapple buckets rock
If brings up a good point. If you have zero attachements now. You should consider get the loader setup for a skid steer. You can rent the items or right now there is a lot of good stuff for cheap. Grapple buckets, tooth buckets, etc.
I have a grapple setup, but I don't have the power beyond (which is not cheap). I plug the grapple into my rear hydraulic on the 4520. On the 5525 it has the 3rd scv and a thumb switch.
Grapples work nice for grabbing things like trees, etc. I use my grapple and a chipper/shredder on the back. I pick the trees up and cut away. Can clean up as a I go.
D.
   / Loader Question: #10
Good advice - but forks are so cheap and handy - they are a good addition. Unloading feed on pallets. We have built barns around here by standing on a pallet on the loaded. Have a safety harness and clip to the pallet forks, etc.
D.
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A52705)
2024 ATLAS CORPO...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
