LOADER- PUSH/PULL
   / LOADER- PUSH/PULL #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I know that loaders are designed more to lift than push or pull. Any rough guidelines for a new user of NH TC40 DA with 17LA loader regarding limits of operation when pushing or pulling without damage to loader. I'm thinking in terms of repositioning logs for dragging by grapple short distance to staging area for bucking. The actual dragging I may perform with draw bar and tongs.
Thanks for help in advance.
   / LOADER- PUSH/PULL #2
I haven't seen any specs on pushing capacity for loaders. Mostly they loose traction and spin 1,2,3 or 4 tires - that's when you are pushing too much. As to pulling, standard FEL operations include filling the bucket to max capacity, putting it in float and back dragging. You can also add down force and back drag to help level and compact the soils.
I wouldn't be at all hesitant to push or pull any log that the loader could lift. Always be cautious with a log when pushed as it is able to swing around and smack you (or the equipment). This always happens with abrupt speed due to catching a stump or rock in the exact perfectly wrong way.
They make skidding cones that fit over the front of logs and there are angled skids that the front of the log can be chained to. These help the logs bounce over stumps etc when pulled.
As far as damage - that is usually from shock loads. Whacking into objects that don't move. Also unbalanced loads. If you are using forks on the bucket to lift a log and it rolls back and down hard, the cylinders can bend. ( Got a buddy with a banana cylinder from that exact thing).
jb
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2014 Nissan Rogue Select S AWD SUV (A51694)
2014 Nissan Rogue...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
20702 (A51694)
20702 (A51694)
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
