Loader problems
   / Loader problems #1
1tractorsexy
M59 kubota
Does anybody know why all of a sudden? My front loader has problems going up and goes slows down
   / Loader problems #2
About a 98% chance you have a quick couple unseated. Disconnect and reconnect them. It's not always obvious which one it is. Do it with the loader on the ground and relieve the pressure first. If it's not that check that your linkage is giving full range of stroke on the valve spool.
   / Loader problems #3
At the time I thought it was a good idea, I plug my FEL into one of the 2 sets of remotes on my MF563.
Sometimes the lever that choses which set of remotes is being used will not quit go to neutral but also not fully engaged.
When this happens I get similar results. I put a short bungee cord to the lever just to keep engaged.
If that's how you've got yours plugged in anyways. If not, ignore.
   / Loader problems #4
Check the lever on the three point. If it's in the full up position your hydraulic system may be in bypass mode. Pull it a little off of full up. If that solves the problem you need an adjustment on your rock shaft.
   / Loader problems #5
If you have rear remotes, make sure they are centered and not 'deadheading' against the relief valve.
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
72in Dual Cylinder...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
