Loader Options Please
   / Loader Options Please #1
CraigM
Golden, IL
B2150HSD, JD3020
I am looking at the options available to add a FEL to my B2150HSD. Sounds like there are still a few Kubota LA350A loaders out there, but I am told that this unit has been discontinued. Does anyone know for sure? Does anyone have specs or experience with this loader to compare to the Woods 1006 that my dealer recommends. Has anyone ever installed a loader on a tractor with a belly mower? Was it straightforward or not? Do you need an overhead hoist or just a strong helper?
Finally, who else makes a loader for compact tractors and how do they rate?
Craig
Hershey, PA
   / Loader Options Please #3
Thank you for the leads.
Craig
Hershey, PA
   / Loader Options Please #5
Here are the LA350A specs from the Kubota literature
Lift - 84.4"
Clearance - 65.6"
Reach at max height - 19.9"
max dump angle - 39deg
reach on ground - 50"
Digging depth - 6.5"
Height in carrying position - 46.2"
lift capacity - 838lbs
Breakout force - 1442lbs
Rise time - 3.3sec
Lower time (power) - 2.2 sec
Lower time (float) - 4.0 sec
rollback time - 2.3 sec
dump time - 1.3 sec
rated flow 6.2 gpm@2500psi
relief valve setting 1636psi
lift cyl bore - 1.75", rod - 1.25"
Tilt cyl bore - 1.75", rod 1"
Lift cyl stroke - 17.7"
Tilt cyl stroke - 17.7"
B1608 bucket
width - 60"
struck cap - 6.4 cu ft
heaped cap - 7.8 cu ft
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
Chisel Plow with Cultivator Sweeps (A52128)
Chisel Plow with...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
