Loader on CT120
   / Loader on CT120 #1
muzbomb
Canada, Alberta
2016 Kioti 2610HST
Does anybody know what model the front end loader is for a 2007 bobcat CT120 tractor? I want to buy one and I am hoping to see if kioti makes a front end loader that is good for my tractor.
   / Loader on CT120 #2
Rhino may have built some of the loaders for the Bobcat compacts.
Maybe try them also.
   / Loader on CT120
This is what I have found out that it is a Bobcat 6TL loader model that works with the CT120. Now I just need to find out what loader is the same with that one?? I know kioti KL120 sure looks to be the same direct bolt on
   / Loader on CT120 #4
I would contact bobcat first off they can do a search nationwide for you to see if there are any leftover loaders however I doubt there are but you never know. I would think that Koyker, woods, or rhino would have a option for you if you can't get anywhere with kioti. If not having one custom-made would probably not be that difficult.
   / Loader on CT120 #5
I dont believe the CT 120 was loader compatible. You needed to move up to the 121 series to be able to have a loader as and option. I could be wrong, but that is what I remember when looking back in 2011 when I bought my CT 235. I wanted something small with a loader to clean up the horse paddock. Ended up going with the CT 235 to have enough power and lift capacity to do things and use 3pt implements.
   / Loader on CT120 #7
Genie GTH-644 (A50490)
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
2014 TROXELL 130BBL VACUUM TRAILER (A50854)
2014 TROXELL...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
