Loader no workie
   / Loader no workie #1
Rkrollins62
Ford 5000
Ok I have a Ford 5000 with a new Holland 270LT loader The other day I was lifting something fairly heavy when I went to come back down it wouldn’t come down I could bleed it down by cracking the line at the cylinder tighten it back up she would raise the bucket tilts good but won’t come back down I’ve checked all the lines The quick disconnects when I try to get it to raise or lower the lines vibrate and the motor on the tractor shutters like it’s trying to work but it will not come back down
   / Loader no workie #2
Is your 3PH lever stuck in the raise position ?
   / Loader no workie #3
You say it has quick disconnects, and things shutter and the motor on the tractor indicates a load like its trying to work....you probably have a quick connect partly decoupled of or just faulty.
Problem is you can re-connect them under pressure, and the weight of the loader in the air is putting them under pressure.
You need to find a way to support the loader (another loader, jack and 4x4 post, etc) and unhook and reconnect the couplers for the lift/lower
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
