Loader Mounted Snow Plow - Starting the Design
   / Loader Mounted Snow Plow - Starting the Design #1
lostcause
Veteran Member
Maine
I was about to start on the plans for my plow but when I pulled the blade I had I realized it was not in the shape I thought it was when I set it out back a few years ago. I'm starting the search for a suitable donor blade (read between the lines: I'm cheap and want to find a blade as close to new as possible for as little money as possible) before I start with the fine details, but I've still got a larger design issue that I'm wrestling with...
Let's start with the basics:
Approximately 7.5' blade width (likely to be fisher due to geographical availability)
Blade will have a trip edge, or potentially entire blade trip depending on brand / model
JD H165 loader with quick attach (300 series)
Factory 3rd function for blade angle
I've looked at a lot of the threads on here with people's designs, and also looked at the pictures online of the commercially built offerings, though it's hard to see the details with a lot of the canned thumbnail sized pictures available. What I'm struggling with is blade float - from what I can see most of the commercial offerings are fixed mount and would assume that the loader is run in float. Many of the low-brow homemade ones I see are also this way. A lot of the builds I've seen on here would assume the loader arms to be set to a slightly elevated height and then allow the blade to pivot up and down to follow terrain changes - usually with a limiter chain.
I would think the fixed mount with loader float would be the easiest to build and use, so what's the benefit of having the plow pivot up & down with a fixed loader height instead? From what I can tell the consensus is that the loader arms make it too heavy to float the entire unit and steer. Would standard or oversized shoes be enough of an equalizer to offset it? I'm generally wanting to plow completely straight ahead anyways. What about with a poly blade - would you choose differently without the extra blade weight?
   / Loader Mounted Snow Plow - Starting the Design #2
All truck plows have a chain plow float for a reason;I would advise you do the same.Floating the FEL puts too much down pressure.Solid mounts work o.k.for paved surfaces,not so much for uneven or gravel type.Lots of good home-made builds on this site.
   / Loader Mounted Snow Plow - Starting the Design #3
Went through a lot of research before building mine and decided the best was to float the blade on chains, PLUS build the frame so the weight of the loader frame (or even the front of the tractor) could be brought to bear on the plow frame for stubborn spots. There is a lot of detailed information here and on OTT as well as YouTube. Paul Short has a lengthy commentary that's useful.
My build was with an 8' Fisher. The bottom trip edge is nice and the height of where the A frame connects to the blade helps keep the rest of the frame from inadvertently dragging on the driveway.
Keep us posted on your progress.
   / Loader Mounted Snow Plow - Starting the Design #4
Listen to Galen Koekeritz's tape Minnesota implements new floating snow plow. - YouTube I liked his ideas well enough to buy. To address the problem of the front tire to blade distance, many of the self-builds on this forum have used truck plows but set the transverse pins upon which the A-frame floats behind the plane of the SSQA plate.
   / Loader Mounted Snow Plow - Starting the Design #5
The guy is a genius!
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
New Long Forks (A53002)
New Long Forks...
