Loader leakdown
   / Loader leakdown #1
smilingreen
Lebanon, Tennessee
JD 5055D, JD 790 MFWD
Hey guys...
I have a #70 loader on my 790 and was wondering if you guys have problems with the bucket curl leaking down. I have probably 150 hours of dirt and rock moving on it. When I pick up a full load, within 50 feet or so, I have to curl it again. It doesn't make any difference if the engine is running or not. What do you guys think? "O" rings in the cylinders or the DSV manifold. Anybody have this problem??
Dave
   / Loader leakdown #2
I have a #75 on a 1050. I had problems with the lift circuit leaking down. My problem turned out to be in the valve body. Rain had gotten into it and ruined all the small parts in there. I replaced everything replaceable, alas, not everything I needed was available. It's still not perfect but its functional. The whole valvebody is megabux so I hope this isn't your problem.
   / Loader leakdown #3
A simple test will let you know if the problem is in Cylinder or SCV valve......
Roll back and unhook scv lines for buckett curl.....test if it does not move your problem is in the SCV....
edv
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51243)
2016 KENWORTH T270...
2015 Kia forte (A50324)
2015 Kia forte...
