loader joystick TN75DA
   / loader joystick TN75DA #1
SmallKyFarmer
TN75DA
I have a problem with my joystick in the cab. This loader stick has a ring that slides up and down as a locking device to lock out the loader. Somehow now the ding has to be just right not to low or locked not to high or there is so much slop you have to open the side door to dump the bucket. Is there a parts diagram for these joysticks? I have the worst time navigating NH parts catalogs for some reason. Old age I guess! Thanks for any help!
   / loader joystick TN75DA #2
I'm sure there is. I know what you mean though. Italian to Engrish. Written from the fiat dept.
It takes me awhile to remember where to find things. All I can remember is there are 2 cables going to the remotes (mine is an early model, uses the rear remotes; iirc, a tn75 probably has temotes under the drivers right foot). You can look for the remotes and see if your cables are mounted correctly. If you search here for a TN model and loader joy stick you ought to find others with issues through the years.
   / loader joystick TN75DA #3
You should also be able to adjust the cables, when the stick is locked in the middle, to eliminate excess play.
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
