Loader Hydraulis not working
/ Loader Hydraulis not working #1
Rdunnebacke
TC, MI
Rhino 404
Next Problem. On to my non working loader hydraulics. I assume that there is air in the system when I cracked the tractor in half to fix throwout and fingers. Now that I have bled out the fuel system, how do I get the air out of the hydraulic system?
Thx RD
/ Loader Hydraulis not working #2
Open center system (fluid flows constantly unless controls are diverting to a cylinder), so just make sure it has proper amount of fluid and let it run to purge air. If you already have and it still doesn't work, then check to be sure you put the connections back properly.
Edit - Check the connections first. If the fluid doesn't have a place to go, then damage can happen to the pump or lines before it dead-heads unless there is a relief somewhere on the "new" circuit design.
KPArk: Your saying that the pump will suck the air out of the pickup tube and eventually will be able to suck up the oil from the sump?
/ Loader Hydraulis not working #4
Most pumps will purge air some have a bleed screw. I have no idea on your tractor. Does power steering function?
Ok spoke to Tim at Farm Boys and had to bleed the bango fitting on the right side of the seat. Main line out of the sump. Thx Tim
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
New/Unused ATS Lifting Motor (A65583)
New/Unused ATS...
2018 INTERNATIONAL HX620 (A65643)
2018 INTERNATIONAL...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
