loader/hydraulics question
   / loader/hydraulics question #1
mattellis2
Bronze Member
I need some advice/knowledge on hydraulics systems. I have been looking to add a front end loader to my little tractor (Branson 2910). I was quoted almost $4K (ouch) by the local bush hog dealer for one that would fit my tractor.
There is a fellow in the next town over that has the next larger model number for sale for $2.5K, and I would like to jump on it, IF it can be adapted to by tractor. I know I'll need the mounting brackets and all, but my real question is about the pump system. My tractor is rated at 8.25 gallons per minute @ 2000 psi. According to the bush hog loader manual the model that the guy has for sale is rated for 9 gallons per minute at 2450 psi. Will the larger loader work with my system, just with reduced capacity/cycle times? If so, I can live with that. Is there an auxiliary booster pump that can be plumbed into the system to meet bush hog specs? For what it is worth the bush hog loader number is 2346 QT. The guy at the local tractor yard quoted me a 2045.
Final question, what is the difference between mid-mount and front-push loader?
Thanks,
-matt
   / loader/hydraulics question #2
Hi Matt,
To answer part of your question, just as you suggested, that loader will work on your tractor with reduced capacity and cycle time.
Most loaders are matched to specific size tractors and dealers know how to do that, but then there is also an overlap where a certain size loader might work on different size tractors. A range of size or HP. For example, I could have gotten a smaller or larger model loader on my tractor, since there was an overlap of what the loaders would work on.
The key is not to get either too small or too large. Too small and the tractor could damage the loader by over powering it in circumstances. Too large and the loader could pick up more weight than the tractor is designed for, consequently damaging the tractor. In your case, perhaps the lower GPM and PSI will offset the larger loader size (which is often a handy feature). Sounds good to me and I would give it a try if you can get attaching brackets that will fit. Also be sure to get the brackets that tie the rear end into the loader subframe to distribute the stresses throughout.
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2000 Ford Ranger Pickup Truck, VIN # 1FTYR10V0YTA06580 (A51572)
2000 Ford Ranger...
