Loader hydraulic Quick Connect couplers
   / Loader hydraulic Quick Connect couplers #1
greenthumb
SE/Mid Michigan
tc40, exmark lazer Z
I have TC 40 that has one maybe two leaking quick conectors for the FEL. I looked at them with the loader unpluged and can see that one is missing part of the gasket on the tractor side. I figure that is why I am leaking oil. my question is what is the best way to remove them and do I simply replace the bad ones or can they be rebuilt? what would be the most cost effiecent. My second question is what is the best way to remove the coupler there is not much room between the loader mount and the side of the tractor.
   / Loader hydraulic Quick Connect couplers #2
If you're talking about an O-ring, yes it can be replaced. I would remove a good one using a straightened paper clip with a small hook bent on the end. Then take the good O-ring to most any local bearing shop so they can match it up. O-rings are inexpensive.
40 CONTAINER (A52472)
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
