I am instslling a koyker 160 on my TL3200. I found the adapter block will not work with the hydraulic tilt linkage on the three point hitch. What is a good way to tye into hydraulic system. thanks Larry
Check out this web page hoye tractor .
I cut a section out of the line just like in the diagram. I'm pretty sure your loader valve is open center.
I had to go to a hydraulic shop and buy a few compression fittings. The ones I bought I had to flare the steel line to work. This photo is from
