Loader Hydraulic Fluid
   / Loader Hydraulic Fluid #1
Rambo
I have a 1610TS, and was wondering where do you put the hydraulic fluid in for the loader. Above the bucket is a cross bar which has a metal cover to protect the lines.I was wondering how to take the lines off the cover with out the fluid running out. The metal cover is bent, so I was wanting to bend it back out. Thanks for any help. Rambo NC
   / Loader Hydraulic Fluid #2
Does the loader run of your tractors standard hydraulics, is the line from the pump routed through your loader valve?
If it is, you need to add the fluid to the hydraulic tank behind the seat. Has a screwed cap (about 1 1/2") with inbuilt dip stick, high mark is to the top of the stepped section.
Thanks John. You are correct. It is behind the seat. Thanks for the help. Rambo
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
