Loader Hydraulic fluid question..???
   / Loader Hydraulic fluid question..??? #1
Jer
So. California
Two tractors..both Mitsubishi. MT160D 4WD with a Brush Cutter. The other is a MT1601 4WD with a loader
I just bought a Mitsu..MT1601D with an Allied #95 loader. I want to change the transmission fluid on this tractor which as I understand operates the loader as well. If I just drain the fluid per the tractor manual, clean the filter and fill with new fluid, is there any thing else I have to do to the loader lines?.....do I need to bleed air out of the lines some way.,.or does the hydraulic pump just naturally take care of that???
Jerry in CA
   / Loader Hydraulic fluid question..??? #2
The loader lines will bleed the air out when you operate it. Just run it all the way up and down a few times. Might be jerky at first and that is fine, but will smooth out.
Ben
Toro Mower (A50324)
Toro Mower (A50324)
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
CAT 416B (A47477)
CAT 416B (A47477)
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
