Loader Height Help
   / Loader Height Help #1
Anonymous Poster
Epic Contributor
One of the safety warning decals on my BX2200 shows the loader up in the air contacting electrical wires. I can't seem to get the loader that high in the air. Can someone help? I of course don't want to hit electrical wires, but I would like to have the loader bucket 16 feet in the air when pushing down trees. /w3tcompact/icons/wink.gif
   / Loader Height Help #2
The warning is for areas that have much lower electrical lines. /w3tcompact/icons/smile.gif
But if you really want to raise the loader height, you could always use the old trick that lots of people use to dump in a truck that's too tall - ramps.
Mark
   / Loader Height Help #3
When the bucket is fully raised, it's probably almost over the tractor radiator. I wonder if the tractor could be damaged? If a stump broke off, the but-end may come up hard under the tractor. Seems like there's also a good chance of a dead limb falling on you or the tractor when working that close to a trunk. I think I'd rather take down good-sized trees with a chain saw and worry about the stumps later.
Codes for service line here are 15' foot residential and 20' where farm equipment may be operated. Many service connections pre-date the codes and are lower. I can see how it would be easy to be concentrating on doing a job and forget about overhead service lines. A friend of my brother-in-law's was killed last summer like that, but while using construction equipment rather than a tractor.
I have to remind myself to check if my wife left the clothes line up or down. If I snag a line with wash on at the other end, I could end up looking like a ship flying a message. The message probably would be: 'It's time for dinner, and you're it.'
   / Loader Height Help #4
Del.
I'm not sure how bigger trees you are planing to push down but be very careful.
Don't forget the base for the tree also the root system will pop up,and the last thing you would want damage under your tractor or yourself.
When I remove a 6" tree or bigger I cut about 2 to 3 feet from the base, than I can use the front loader or chain to remove the stump.
Just about every tree has what we call a willow make limb,so once again please be careful.
Electirc lines warning,that warning also for buried under ground electric lines as well.
If you can raise your bucket high enough to touch above ground lines than you need to call your locate power company and have your lines bought up to code to your weather head.
Have fun and stay safe.
   / Loader Height Help #5
Thomas, I guess you're talking about what I've always heard called a "widow maker" limb./w3tcompact/icons/laugh.gif None of them have made a widow of my wife yet, but I've been slapped around a few times by some of them./w3tcompact/icons/frown.gif
Bird
   / Loader Height Help #6
Re: Loader Height Help..Bird
A number of years ago people starting growing weeping willow trees,and after having the willows for years people wanted them remove for they always seem to be dropping limbs,also the tree may look go but a good strong wind seem to break them in half or up root them.
Many people were hurt removing the weeping willow tree and some of the people did weep after being hurt,so I guess the name caught on if you got hurt while removing a tree....willow maker.
I guess one could call it that good old yankee humor. :eek:) Yes your right Bird about the widow maker,for thats another term thats used,and I hope it doesn't happen to any of us.
Take care stay safe.
   / Loader Height Help #7
Thomas, the willow maker is a new one on me; never heard that before.
Bird
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
