Loader for New 45 HST
   / Loader for New 45 HST #1
Barj
Hi, does anyone know which loaders are going to work on the new DK45SE HST? It's unclear on their web site. Thanks.
   / Loader for New 45 HST #2
It will be a new loader. KL401 I think. I don't have the full specs on it yet.
Thanks.
   / Loader for New 45 HST #4
Specs for the KL401 are on the website but they don't have it properly linked to the DK45hst page yet.
   / Loader for New 45 HST #5
AWESOME SPECS!!!!!!
BTI
   / Loader for New 45 HST #6
Are the new loaders curved? Does any one have cycle times for them?
   / Loader for New 45 HST #7
Here's the photo from Kioti's site.
   / Loader for New 45 HST #8
At the end in bold, I beleive that is in seconds. Pretty impressive!
A - Maximum Lift Height 107.8"
B - Clearance with Attachment Level
105.5"
C - Clearance with Attachment Dumped 79.9"
D - Reach at Maximum Height 16.1"
E - Maximum Dump Angle 73 degree
F - Reach with Attachment on Ground 73.6"
G - Attachment Rollback Angle 30 degree
H - Digging Depth Below Grade 6.7"
J - Overall Height in Carry Position 52.7"
L - Depth of Attachment (to back of inner shell) 20.7"
M - Height of Attachment 22.6"
N - Depth of Attachment (to pivot pin) 25.9"
Lift Capacity to Full Height at Pivot Pins 2,761 lbs
Breakout Force at Pivot Pins
3,727 lbs
Relief Valve Setting (Loader Control Valve)
2,556 psi
Rollback Force at 500mm forward on the ground
4,633 lbs
Rated Flow (Tractor System) 10 GPM
Lift Cylinder
Bore 60 x Rod 35 x S.t 485
Bucket Cylinder
Bore 55 x Rod 30 x S.t 525
Attachment used for Specification
72"
Raise Boom 7.6(1,500rpm),5.7(2,000rpm),4.5(2,600rpm)
Lower Boom
4.9(1,500rpm),4.8(2,000rpm),4.8(2,600rpm)
Dump Bucket
6.2(1,500rpm),1.9(2,000rpm),1.5(2,600rpm)
Retract Bucket
2.3(1,500rpm),2.2(2,000rpm),2.1(2,600rpm)
   / Loader for New 45 HST #9
Where diod you get the bucket cycle specs. I do not see them on the web site? Do you know if the 551 is self leveling, I hope not !
   / Loader for New 45 HST #10
So far I have not been a big fan of the self-leveling on the bucket but I'm sure it's all in what you use it for. I was so comfortable with the bucket on the JD that it's hard to adapt. How do the specs on the new 45 loader compare to the old loader, better or worse?
2002 FREIGHTLINER FL60 SERVICE TRUCK (A52472)
2002 FREIGHTLINER...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A51692)
2002 Western Star...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
