Loader cylinder
   / Loader cylinder #1
NC1710
How Do you get nut off of cylinder? turning with pipewrench the nut turns but its not unscrewing. Thank for any info
   / Loader cylinder #2
That is not a nut, depending on which type you have, if you look near the end, you should see a small slot. In that slot is what looks like a "flat wire". Turn the end of the cylinder until you find the end. Fish it out then turn the end and it will extract the wire (you should see one in your rebuild kit.). That wire fits in a grove that holds the end on. On some types you can just pull it out once you get it started.
Hope this helps,
Gary
18005 (A51691)
18005 (A51691)
UNUSED FUTURE 3T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 3T...
18009 (A51691)
18009 (A51691)
Case IH 2388 Combine (A50514)
Case IH 2388...
10ft Fork Extensions (A50322)
10ft Fork...
