Loader controls won't raise loader
   / Loader controls won't raise loader #1
fruitcakesa
Veteran Member
CavendishVT
M6040 JD 450C
I was picking up a log with the loader when I felt a "pop"in the joystick control and the loader stopped lifting.
I still have curl function and downward movement. I have not opened up the control cover yet.
I was looking for a blow up pic of the loader system but can't locate one; anybody have a link and advice?
LA 1154 loader on my M6040
   / Loader controls won't raise loader #2
I there are any quick couplers on the loader one of them probably disconnected. May not be obvious. Best to uncouple and recouple to be certain. Do this with the loader on the ground, the tractor shut off and the loader valve relaxed. You might want to move the tractor to a good place to work on first in case this isn't the problem before lowering the loader.
   / Loader controls won't raise loader #3
Does the joystick feel like it is loose in the raise lower operation vs curl dump? If yes them something in the mechanical connection has failed. Is the joystick mounted directly to the valve or are there cables running from joystick to valve?
I believe messicks has an online parts diagram for Kubotas.
Was a broken cable that I was able to locate locally and get it installed and adjusted.
   / Loader controls won't raise loader #5
Thanks for letting us know the what problem was and glad was simple fix.
STORAGE FEES (A51219)
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
