Loader capacity?
   / Loader capacity? #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
I am a tractor novice. My son and I recently purchased a 1999 Kioti LK3054 with a Kioti KL122 loader. The bucket is 54". The loader manual shows the lift to full height capacity at 760 lbs and the break away at 1580 lbs. Here are a few questions:
1. I have no idea what a bucket load of something weighs. Any ideas on heavy, wet snow, dirt, gravel, sand???
2. What does the 760 lbs actually mean? Will it lift more but could be damaged with a heavier load? Will it just not lift more? Do we have to be cautious in what we lift?
3. Is the 760 lbs light for this sized tractor?
Thanks!
   / Loader capacity? #2
Don't over think this.
Keep your load low while traveling,
Keep your tractor level when lifting above the wheels,
Keep your common sence where you can get at it real easy.
Keep the shiney side up!
Start out easy and get to know yur tractor. Pay attention to how it "feels" during different situations, nothing beats "seat time". Once you know this, you will know just how far to push your tractor safely. The weight rating is prolly a safe lawer derived weight limit. You prolly can't hurt your machine by lifting up too much. That is, if it will lift it (may not be safe) it's ok, hydraulics have preset bypass values built into the unit that will should just stall the hyd. if if the load is too heavy. Check out some weight/ cubic ft. on line of different materials, it'll suprise you, and just try to stay within the sugg. load limits. Have fun!
   / Loader capacity? #3
+1 what Rustyiron says. A little experience and common sense are the first requirements. The "breakout force" is how much strength the "curl" has for the loader. If you're digging in hard ground, for example, how well can it break loose packed soil. The lifting force is pretty obvious. Most loaders can lift a full scoop of wet soil or "crusher run" (gravel and fine stone dust used in road or driveway foundations)... those are some of the heaviest materials commonly encountered.
You won't be able to lift the maximum capacity unless you have counter-weight at the back of the tractor (an implement and/or ballasted tires) to hold the back end of the tractor down. And lifting a full bucket all the way makes the tractor very tippy to the side, so be careful and do it only on flat, level ground. Low and slow when transporting anything in the bucket, whether you're going 10 feet or 1,000 feet. Be in 4wd at all times, except on pavement. And wear the seatbelt.
You'll acquire a sense of your machine's limits as you use it. Just don't try to find the edge of the performance envelope in the first 2 hours of operation. :D
   / Loader capacity? #4
I have a lk3054xs tlb with the 1231 loader
First the hydraulics bypass will kick in before you lift enough to hurt the machine
MY loader easily does somewhere around 1000 lbs
Please keep load low and hand on lever when on slope to drop load should you start to tip and keep your seat belt on and rops up
Joel
   / Loader capacity?
:D
The LK3054 seems to be a heavy tractor for its size at nearly 3000 lbs and the previous owner filled the back tires with calcium so hopefully this will give it enough ballast.
"I have a lk3054xs tlb with the 1231 loader.
First the hydraulics bypass will kick in before you lift enough to hurt the machine.
Joel "
Looks like your loader has a capacity of about 160 lbs more.
   / Loader capacity? #6
Don't assume those ballast tires will be all you need. Doing some simple loader work it may be OK but fully weighted it could still get tippy. With my loaded tires I can lift until the hydraulics say enough but moving with that much weight is another story. I have some brown underware to prove it.
   / Loader capacity? #8
Joel
just stumbled on this after a Google search for a used tractor I’m looking at purchasing.
My main concern is lifting a round bale of hay.
Has anyone had direct experience lifting a round bale?
   / Loader capacity? #9
We it the forks on and spread wide. Jab forks in two bales on front and one on spike at rear when moving hay. When it's stacked we get 3 of 6 x 6 rolls on front.
   / Loader capacity? #10
I think it would struggle. Depends on bale size and density. But stacking would be out of the question. I have the same loader and have the pressure turned up and I would not want to move hay with it.
I suggest keep looking.
EZGO (A50324)
EZGO (A50324)
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
STORAGE FEES (A52577)
