Loader all of a sudden has no down pressure
   / Loader all of a sudden has no down pressure #1
Timber
Veteran Member
East Bridgewater Massachusetts
Kubota B7800
I have a b7610, was out working with is and it was working fine and then the loader wouldn't drop with pressure. When I push the joystick the loader doesn't mover. It will lift fine dump and curl fine but will not drop under hydraulic pressure. It will only drop if I push it into float and then gravity will let the loader drop. When it is on the ground and I tip the bucket it will lift the tractor. Any thoughts on this. The quick disconnects appear to be working but 1 was a little sticky.
   / Loader all of a sudden has no down pressure #2
Maybe you can swap the up/down hoses and see if the problem is changed.
Wilco
   / Loader all of a sudden has no down pressure #3
Re-seat the QD, sounds like one of them in not seated.
Swap hoses to check.
I'm thinking one of the of the QDs is bad. I'm picking up 1 set tomorrow. It's my dads tractor.
No still no luck I am still waiting for a QD because 1 has a seized collar but its in the dump and curl. I did get a coupler to bypass the lines individually. I'm thinking that as soon as I get the new QD ill pull my tractor next to it and mover the lines from his tractor to mine and see if the loader operates with down pressure and go from their.
   / Loader all of a sudden has no down pressure #6
Switch the curl hose and check the lift cyl for lift and down pressure.
You are simply pushing fluid into the cyl to test cyl integrity. If the valve spool is good and the cyl is good, then the cyl should be able to raise the front wheels off the ground.
A coupler instead of the QD's should have given you the answers you need.
Are you trying to do this in the regen mode?
Are you using curl down to raise the wheels off the ground.
If you are trying to raise the tractor, try tilting the bucket straight down, and then push the lift arms lever for down force.
   / Loader all of a sudden has no down pressure #7
Have you checked your hyd fluid level in the tractor. Any possibility there is air trapped in the system? Ken Sweet
   / Loader all of a sudden has no down pressure #8
From what the poster said, there is flow in one direction, but not the other, and that is related to QD's
The QD's are not passing fluid in both directions.
I'm still going with a QD as the likely problem, the tractor has been sitting for some time, my Dad bought it just over a month ago. I was using it and all of a sudden it simply had no down pressure. The only way to lower the loader once it is up is putting it into float and gravity will bing it down. 1 of the QDs the release collar is seized but the hydraulic fluid does flow. I have 1 coupler and replaced it on both QDs 1 at a time but it didn't change anything.
   / Loader all of a sudden has no down pressure #10
This is not making sense at all.
If you remove both hoses going to the cyl and put them in a bucket, and move the lift arm lever up and down, do you get flow in both directions?
The fluid does flow in one direction due to the fact that you applied fluid to the base of the cyl and it raised, but can you verify that the fluid from the base is flowing back to the tank when you retract the cyl rod.
Otherwise, can the fluid make a round trip? You should be pushing fluid back and forth. ???????????
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52141)
2017 AUTOCAR YARD...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
T3 Motion Patroller Segway (A51694)
T3 Motion...
