bowhunter3030
- Joined
- Dec 22, 2004
- Messages
- 140
- Location
- Collinsville, IL.
- Tractor
- Kubota Grand L4060hstc & Kubota B2601
After several attempts to get my loader on my B3030 level, is 5/8" good enough?
bowhunter3030 said:After several attempts to get my loader on my B3030 level, is 5/8" good enough?
RoyJackson said:Check your tire pressure in all 4 corners!
If the pressure is equal on both sides and in spec...
Why isn't the loader level? And, are you measuring from a surface that is flat enough to make your measurement accurate?
Is it a new loader and/or tractor? If so, that's a dealer question.
Are you doing the initial installation of this loader?
Otherwise, as long as there is no binding and it moves freely...and removes and installs with no problems, it's probably safe to use. But this isn't optimal by far.
So, if you must use it, go ahead..but don't give up on trying to fix it.
Which brings me to a question...how much side to side variation is allowable? Due to production tolerances (and stack ups), my guess would be 1/8th inch. Anyone have any factual response to that question?
_RaT_ said:The problem is, if you make 1/8th inch the "off the shelf" tolerance, I think most loaders from any manufactuer will fail the test.
For most of us using the loader for all but the most detailed work, even 5/8" will not alter the loaders ability. Would I rather it be level? Sure, but the loaders on compacts are not nearly as robust as the industrials. The likelyhood of them having or developing a 5/8" difference is not that unusual, not in my experience.
RoyJackson said:I threw out the tolerance of 1/8th's based upon commonly used welding tolerances of 1/16th.
That allows quite a potential for a tolerance stack...more then an eighth, I'm sure.
The question was "Loader 5/8" higher on one side. Is this ok?" This really needs to be answered by the manufacturer's Engineering Dept since all we can do is guess.
It's pretty apparent the dealer doesn't know either, based upon bowhunter3030's last post.
bowhunter3030, I'd be very interested in what the Factory Rep has to say...
Then he deserved it for mowing the FEL on._RaT_ said:Maybe he crashed it into a tree while mowing one day, that might explain it.
_RaT_ said:My neighbors little JD 790 has a loader that is no where near level anymore. I don't really know how he did it, it barely has much more then a 5 cu ft bucket and very small lift cylinders. Maybe he crashed it into a tree while mowing one day, that might explain it.
RoyJackson said:Probably lifting on the corner of the bucket and sprung the frame.
I can say I've ever measured mine...looks fairly level, so I reckon there isn't any problem.
bowhunter3030 said:Rep said 5/8" of an inch is not out of line. He said the tires can be 3/8" of the problem plus the arms variable. I measured from the bottom of the loader arms, not the bucket one side barely resting on the ground. He also told me that the quick disconnect might add to the 5/8" out.
Excellent idea..... I was going to post this but you beat me to it. I've done this on a couple of Kubota loaders with success as I knew at the time nothing was abused/bent.DiezNutz said:Then he deserved it for mowing the FEL on.![]()
Anyway... mine isn't that level either (always been that way). It was built after the fiasco with the uprights, so I'm pretty sure that isn't it. One of these days I'm just going to pop all the pins out and put it back together on my (level) garage floor.
Thanks, glad to hear it. Reinforces my optimism that it will do the trick.sunnyside360 said:I've done this on a couple of Kubota loaders with success as I knew at the time nothing was abused/bent.
