loader 226D
   / loader 226D #1
PeteV
Bronze Member
NW Ohio
Yanmar 226D
Does anyone out there have a 226d with the original factory loader on it ?? I'am trying to figure out what the load lifting capabilities of this original unit is to compare to my bushhog 1846qt. Would like to put on a larger bucket, but don't want to overdo it
Thanks Pete
   / loader 226D #2
The YFL875 could be fitted with a 60" material bucket or 72" snow bucket. I don't have capacity of the buckets.
   / loader 226D #3
Pete, The YFL875 could lift 875 lbs to the full height, about 7'.
It could lift 1200 to 1400 lbs off the ground, if you had adequate rear ballast. Plus, the valve was adjustable so you could turn it up or down. I would not want it any higher! I have mine set at 1200 lbs lift max. Gary
   / loader 226D
Thanks guys,
Looks like a bigger bucket might work then. I modified the Bushhog bracket so it is tied to the rear differential housing(just like the ym installation)and added some plates to the bracket itself to stiffen it up. My main worry was front axle loading, but it does not appear to be a problem,
Guess I'll go look for a 60" bucket
Thanks Pete
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
