Tires Loaded tires
   / Loaded tires #1
Carl Bert
Platinum Member
Rockland county, New York
Kubota B26, John deere X595
Can someone tell me what "loaded tires" are? I realize it is filling the tires with something to add weight, but with what, and how do you go about doing this? I just bought a Kubota B26 and considering it is somewhat of a lightweight machine, I thought loading the tires might be a good idea. Any input would be appreciated.
Carl B
   / Loaded tires #2
Typically a mixture of water and calcium chloride to keep them from freezing. I guess some areas can use just water but not where I am. I assume they have an adapter for the valve and through that push in the pressurized solution.
Simply weight for traction, nutin more.
   / Loaded tires #3
Do a search here.. there are dozens of threads on how to and what to use...
this is a common topic...
J
   / Loaded tires #4
Agreed. The only other wrinkle is that there's lots of advice recommending not to load tractor tires if using a backhoe. I didn't. Loaded tires do little good if they're not on the ground... and if you have a BH to counterbalance the FEL, you don't need them for that purpose either.
I imagine that advice extends to a TLB like a B26 as well. I would scope it out first and decide, I'm sure it's been discussed somewhere.
   / Loaded tires #5
One additional note:
If you do decide to do it yourself just remember not to fill them completely. They should only be filled to a max of 70-75%.
   / Loaded tires
Thanks guys. I guess the first thing to do would be to make sure it won't in any way affect my Kubota insurance, or even the warrantee. Don't see why it would, but I just read a post on "Mytractor" where the member said otherwise. I will look into it.
Thanks again
   / Loaded tires #7
Thanks again
If it does.. alot of us are in trouble!!
The dealer filled mine before he delivered it!
J
   / Loaded tires #8
I just loaded mine with Polyethelene glycol (RV antifreeze) got it at tractor supply. $4 per gallon kinda high dollar, but it is non toxic, so if you have a leak it won't kill all your animals. it is supposed to be non corrosive also.. I would not recommend calcium cloride (a salt mixture) it does weigh more, but it is corrosive, and you must use tubes which means if you have a puncture, you must drain the tire and patch it and the tube. otherwise you could just plug the puncture in a tubeless setup.They say the best is Rim Guard, a beet juice mixture, but I couldnt find any dealers locally, and it is dealer only deal. I bought the fill adaptor at Tractor Supply, and the little $6 pump at home depot. whole deal took about 3 hours from start to finish. Most difficult part was jacking up the tractor, and getting the jack stands positioned. If you want details contact me. and I will go thru it with you.
James
K0UA
   / Loaded tires #9
We also use rim guard as well as the calcium chloride mix. The rim gaurd is a freindly product to metal and ground with leaks.
We have foud with farm tractors that to go to cast weights when needed that they are a one time purchase no matter how many leaks you get!
We have also found that by not having the liquid in the tires the side wall can flex more as well as quicker! It actually allows the tires to conform to the ground quicker and be able get more tracction!!!!
This has given farmers extended life on tires by over 100%
How ever some people enjoy loading there tires and making a tractor feel heavy or as explained a more solid feeling. This is not great for the pocket book but makes them feel good!!!!
My recommendation is to try it with out, you can always add it later!
   / Loaded tires #10
I put weights on my smaller tractors and liquid in the bigger ones. We have an older model Case with no weights and no fluid as all we use it for is bush hogging and it won't pull worth a darn, but works well for mowing.
2018 John Deere 460E Articulated Dump Truck (A52128)
2018 John Deere...
7' Snow Blade (A50515)
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
71061 (A49346)
71061 (A49346)
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2001 JOHN DEERE 8410T TRACTOR (A51243)
2001 JOHN DEERE...
