Loaded tires with backhoe attached...
/ Loaded tires with backhoe attached... #1
Talionstallion21
Monadnock Region, NH
BX25D
Who unloads their tires when they put their backhoe on? Was reading my bx25d manual and it said to unload rears when attaching and using the hoe. Do all of you do that? Is it really bad if you don't? My dealer is 50 minutes away and I don't have a trailer so it would be spendy for them to come here twice a year. What say you?
/ Loaded tires with backhoe attached... #2
I don't unload the rears on my B2620 for backhoe operation. Frankly just don't want the hassle and expense. I don't know the repercussions though, so I'll be interested in others opinions.
/ Loaded tires with backhoe attached... #4
May want extra set unloaded rear tires considering dealer pickup delivery plus service charge for the future.
/ Loaded tires with backhoe attached... #5
Any chance there's a misprint or maybe a 翻訳 problem?
Maybe they mean to lift the rears off the ground, rather than emptying the tires of ballast?
That's standard operating procedure to get the support on the wide set, rigid stabilizer pads and off of the narrow, flexible tires. Maybe the stabilizers can't lift the rears with the added weight of the ballast?
If given the option, I'd want ballast in the rears with the hoe on, for increased lateral stability.
Even with the rears in the air, it's weight that lowers the CG, making slewing with an extended boom & heavy load less likely to cause the tractor to tip.
I'm curious about the reasoning, if that's really what is recommended.
-Jim
Page 55 of my owners manual says "while bt602 backhoe is installed on the tractor liquid ballast in the rear tires should be removed".
/ Loaded tires with backhoe attached... #7
Yeah, I've seen this discussed here before, but I don't recall anybody coming up with a good explanation.
/ Loaded tires with backhoe attached... #8
Yes, it has come up on occasion, and I've never seen a good explanation either. I can say that, even though my BX24 has the same in the manual, I've ignored it as it just doesn't make sense to me. At almost 1000 hours, it's never caused any issues.
I have to say, I don't use the BH that often, just a few times a year. But when I do it is for hours at a time.
/ Loaded tires with backhoe attached... #9
Not sure why the loaded tires should not be used with a bh . Maybe it has to do with the stabs having to lift the tires? My 2620 has no problems lifting the tires that are filled with calcium. Oh well, no problems so far.
Sent from my iPhone using TractorByNet
/ Loaded tires with backhoe attached... #10
The Deere 448 backhoe manual doesn't state anything (that I could find) about removing any liquid ballast from the rear tires. It also indicates (and shows in pictures) the rear tires should be just off the ground and the rear supported by the stabilizers, when operating the backhoe.
It's possible the backhoe, along with ballast in the rear tires, may overload the rear axle. If any of you find out why Kubota states "no ballast", I'd like to know just out of curiosity.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2020 Sellick S80 (A60462)
2020 Sellick S80...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
Giyi GY-SF60 (A60463)
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
