Tires loaded rear tires
   / loaded rear tires #1
HEC
Veteran Member
Maine
Kubota M5700 @ B2650HSDC
I have loaded rear tires and was wondering if you guys who have loaded rear tires run the same air pressure . The salesman mentioned I could run much lower pressure with loaded tires . I wasn't sure if he was correct in saying that or not , or just trying to make a sale . The reason for less pressure was so it would go through my garage door opening . The book not being loaded says 20 psi..
   / loaded rear tires #2
I don't know why you would run at lower pressure. If running at less pressure makes the tires enough flatter to make a difference it seems to me it will have a very negative impact on tread wear. Sounds to me like he's trying to make a sale based on invented information.
Terry
   / loaded rear tires #3
I have always read you run the same pressure, loaded or not. It is what I do. I run the recommended by the manual pressure which is 20 lbs for my rear tires.
   / loaded rear tires #4
It would not matter to the tire loaded or not if inflated at the recommended tire pressure. Unless your dealer has an argument otherwise.
   / loaded rear tires #5
Not according to the Tire and Rim Association (the association that controls the tire standards) plus all the major tire makers. In fact they state the total tire load should be included in the inflation pressure. Note the sidewall will state the maximum inflation pressure, but the load/inflation tables published by the T&R Assn plus the manufacturers will show the tire load capacity for various pressures. As an example, the 17.5Lx24 R-4 tires on my CUT are rated for 4400 lb each at 20 psi and 5360 lb at 26 psi (the 26 psi pressure requires an 8 ply tire. I don't know of any CUT that comes close to putting 8800 pounds on the rears even filled so 20 psi is the max and min for the 6 ply tire. So you need to keep the same pressure. These numbers are for R-4 tires. R-1 tires of the same size have a much lower capacity, 3080 pounds at 16 psi for the 17.5L x 24 tire. The T&R Assn recommends 55 gallons in that tire size for 459 pounds water plus whatever anti-freeze solution used (600 lb with CaCl).
   / loaded rear tires #6
My rear tires are filled with Rimguard and I run them at the pressure recommended by both Kubota & Goodyear. I would think if you under inflate a loaded tire - it would be exposed to additional, unintended tread and sidewall wear and particularly sidewall damage.
Here is a thought - if your tractor is open station and you are needing to reduce overall height, fold your roll bar. I certainly have my roll bar folded to get into the stall space for my tractor.
   / loaded rear tires #7
I have a BX 2350 with loaded tires. I had fluid put in for the added traction I would get on the hills I have here. I was told to use the recommended inflation pressure in all tires as stated on the tires. I run 30 psi on all 4 tires. Have had it for 4 years with NO PROBLEMS at all. I like the extra traction I get, and the better balance when lifting heavy weight with the FEL.
Keep it maintained, and you will be VERY happy with your orange.
   / loaded rear tires
Thanks everyone for the info , I am going to put the 20 lbs back in based on your information . I have a cab so I can not lower that any . It's a tight squeeze but it will fit in my garage after I did a little work on the door and frame . It's amazing what someone will do to make a sale , he even gave me a wrong measurement on the overall height of the tractor right there in front of me doing the measurement . They lowered the air pressure later after filling the tires with rimguard to almost nothing hoping it would fit upon delivery , thinking I wouldn't check the pressure at some point I guess . Oh well things worked out okay anyways .
   / loaded rear tires #9
Nothing better than a uneducated salesman telling ya what to do.LOL
   / loaded rear tires #10
The pressure in the tires is going to keep the bead seated on the rim. That doesn't change whether it is loaded or not. Glad you were able to adjust the door enough to make it work.
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
7' ROTARY MOWER (A51243)
7' ROTARY MOWER...
