load match not on?
   / load match not on? #1
XviperX2
Lehigh County, PA
JD 3320 ehydro
I just got my 3320 last week it is great but the load match switch seems to do nothing? i have stalled it twice doing loader work lifting a full bucket of dirt in low range and about 2200 rpms.
On the digital display if i push the display button to load match settings it reads "loadof" with the load match button in either position?
Any thoughts or help would be a great help before i call the dealer for repair!
   / load match not on? #2
not sure if that switch is controlled by a fuse or not.
   / load match not on? #3
Hiu viper,
I thought the loadmatch worked by increasing RPM's, but after some time with it an continued reading of the manual I believe the loadmatch works by downshifting the tractor to a lower "gear"....
As you're in low there's no "downshifting"...
Still, what you describe has never happened to me, even full of wet clay in 72" bucket in A range
Check out "parts" on deere.com and you can see the wiring diagram for the loadmatch... maybe something has gone on it;
Good luck!
   / load match not on? #4
Once you get the "loadof" on the display, have you tried using the turn signal switch to toggle the value?
   / load match not on? #5
I also have a 3320. The load match does not work for the loader. If you are digging in hard ground you need to use more rpm. The load match only works for the drive wheels. It does slow the tires to keep up the rpm.
   / load match not on? #6
With loadmatch on you should not be able to stall the engine even in low range. It controls the swash plates on the ttransmission and should take you down to a creep.
Somethings wrong...
does anyone know if my digital display should change from "loadof" to "loadon" when the load match button is switched? Because mine dosent change.
just carrying a full bucket of dirt in "A" range up a 5-10% incline drops my rpms from 2000 down to 1300 rpms my understanding is that with loadmatch on your rpms should stay up but your speed will be decreased automatically?
   / load match not on? #8
My 3120 says loadon. I believe the function redirects the hydraulic flow(away from the attachments) to apply more power to the wheels and it does slow the tractor down a bit. with load on you can pull up to a tree and spin all 4 wheels and it will not stall.
Thanks for all the help everyone. Looks like i'll be calling the dealer for service and its not even a week that ive had it home.
   / load match not on? #10
</font><font color="blue" class="small">( With loadmatch on you should not be able to stall the engine even in low range. It controls the swash plates on the ttransmission and should take you down to a creep.
Somethings wrong... )</font>
Yep, very good description. Load Match is designed to slow the hydro drive to a wheel speed the engine can maintain without dropping rpm. It's nothing more than a glorified override of the hydro pedal. You can get the same effect by raising your foot on the hydro pedal as the engine rpms begin to drop. Man's tendency is to push the pedal further down when you begin to lose wheel speed. All that does is increase the wheel speed versus engine speed, which in turn creates less HP to the wheels. If you will lift your foot instead, you will do the same thing as the Load Match. Kinda like the latest gizmo on new cars that takes the steering away from you if it thinks you yanked the wheel enough to cause a roll over. No thanks, I'll drive my own please. Same with Load Match, no thanks, I'll control the hydro pedal please. Load Match has nothing to do with the attachment's hydraulics. Your Load Match is definately not turned on.
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
2008 Toro Workman 200 Sprayer Cart (A50322)
2008 Toro Workman...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
