Load Handler - 2000 or 3000 lb model ?
   / Load Handler - 2000 or 3000 lb model ? #1
450EXC
Central NY
Kioti CK30
Is it worth the xtra money for the 3000 lb model. I see Habor Frieght has the 2000 for 70.00 $ and the 3000 for 110.00 $.
I have a 3/4 ton with 8' box and 5' x 8' utility trailer. Probably loading with gravel, dirt and firewood.
Thanks for the help. Larry
   / Load Handler - 2000 or 3000 lb model ? #2
I would go with the heavier model. I went with the lighter version because they didn't have the heavier model in stock and I can overload it pretty easily. (Of course I'm using it on a trailer instead of in a back of a pickup). When I go to unload it the entire bar bends in. I need to buy a stronger bar.
My 2 cents. Nathan
2018 INTERNATIONAL 4300 BOX VAN (A54313)
2018 INTERNATIONAL...
2020 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2020 VOLVO VNL...
2019 Top Hat T/A 18FT Utility Trailer (A52377)
2019 Top Hat T/A...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
