Load Binders continued...............
   / Load Binders continued............... #1
johnday
Veteran Member
monroe michigan, barton city soon
NH TC 35 had, now a TC35DA LS25 lawnmower
I didn't want to hijack Dargo's thread about the broken straps, even though this is related.
Does anyone know the proper way to use the ratcheting load binders, such as how many turns each end should be inside the ratcheting mechanism? How to know when you've got enough chain taken up? And how about rigging the chains back on themselves thru your D rings?
I've used the lever load binders many times, and dislike them very much. I've got 4, 16', 3/8" grade 70 chains with grab hooks [all US made]. And 2 ratcheting binders. I plan on looping 2 of the chains around the rear axle and thru D rings on rear of trailer. On the front axle, I'll run the chains around it, thru the front D rings, and use the binders on the front to take up the slack.
I was running 4 3" straps before Dargos little trip, but no more. The straps were 3300# WLL, but without looking back, I think I'm at 5600# WLL with the chains.
We can leave cellphone use out of this, PLEASE! /forums/images/graemlins/blush.gif /forums/images/graemlins/smirk.gif
   / Load Binders continued............... #2
John:
I take it the lever binders have whacked your knuckles a few times?? : /forums/images/graemlins/frown.gif
Egon
Egon; It wasn't just the knuckles!! I slammed one down on my thumb a few times. Don't ask how many though! /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
   / Load Binders continued............... #4
first you you find a 4 foot long piece 2" galvanized sch. 40 pipe, and then......hahaha.
I have never used ratcheting type but I have seen them worn out from use (threads worn) so maybe if others agree keep a little bit grease on the threads.
With my lever binders I lace hooks through the attaching point and then hook them onto the chain so when I put the binder in the middle and tighten leaving a dangling loop of chain is just enough to say fit a coffee can through.
Make sense?
On ratcheting I would start tightening with at least three inches of thread engagement.
Steve; Thanks. One question, how big of a coffee can? /forums/images/graemlins/grin.gif
   / Load Binders continued............... #6
This is how I hook mine:
1. Position equipment as needed
2. Layout (4) point ties
3. Loop chain through tie points or around attachment locations
4. Attach binders to chain to tighten.
a. If attaching levers, it seems like you always have to play with them a little bit; i.e. one link too tight one too loose. For this reason, if I use a combo of ratchet and lever binders I hook the levers first.
b. Depending on the amount of take up necessary on the ratchets I preset the travel on each end to allow for apporximately 1/3 of the threaded shaft to remain exposed when secure.
   / Load Binders continued............... #7
Johnday, I'd also like to know the "proper" technique for the ratcheting binders. A good friend owns a construction business and he told me to be sure to leave the binder where the ratcheting motion will only hold the handle down against the bed of the trailer when bouncing along. It seemed awkward at first. I ratcheted the tractor down, and then moved the handle over to where it was against the floor and I'd have to pry up on it against the load. Just as a test, I left the other ratchet handle over on the other side; where it was free to move upwards, but gravity held it down against the bed and not the ratchet dog.
Sure enough, after a trip up to my other property to plant trees yesterday, both ratchet handles were over on the "pressure side down". The handle I'd left on the side I was told not to had flipped over during the ride to match it's partner. /forums/images/graemlins/grin.gif No harm done, but I can see where you don't want the ratchet handle loose and flopping around.
   / Load Binders continued............... #8
Seems like I read somewhere that ratcheting binders were all that were acceptable to DOT anymore.
I may be all wet on this as My memory is sometimes murky at best.
   / Load Binders continued............... #9
Only having just bought my ratcheting binders and chains, I have used them twice. I found that I have to "unscrew" the threaded ends way out first, loop some chain around where I connect to the tractor and hook it on itself (just a small loop) and hook one end of the binder to the leftover chain, the other to the tie down on the trailer. This leaves a length of chain that is not involved in the binding, and I hook that loose end on something on the tractor with the excess lying on the trailer floor.
I ratchet until there's a tight, but not overly tight, grip on the connection points. I had read that the ratcheting binders can easily tighten the chains to their load rating, which wouldn't leave any leeway in case of a stress accident. So, I don't overly tighten them. I took the trailer on a little trip over some rough roads to test, and they held quite well like this.
I hope this is clear, as it's hard to describe just how this looks when done and I'm sure there are several safe ways to do it. I use four binders/chains by the way. John
   / Load Binders continued............... #10
<font color="blue"> I have seen them worn out from use (threads worn) </font> Last one I threw in the trash, the threads were crossed somehow. Strictly lever type for me now and they seem to be imo, easier and quicker to use.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2016 Chevrolet...
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
