Tarnold
In the parts diagram for the hydraulic connections, there is reference to a P hose, C.O hose, and a T hose. Think I know, but to what do these refer?
The P hose is pressure, the T hose is return to tank, and the other is basically a power beyond hose. The pressure port receives pressure from the HYD pump then it transfers the pressure to the Power beyond port that sends the pressure to your loader valve on your FEL, and then the T hose returns the fluid back into your Trans case. I hope I was able to answer your question.
