LK3054xs brake lights not working
   / LK3054xs brake lights not working #1
JoelD
Veteran Member
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Going to work on this later today, any advice. All other electrics appear to work, including flashers, and tail lights when head lights are on. But no brake lights, I'm gonna start first with switch under brake pedal, anyone who's had this problem, any advice is greatly appreciated. Neither brake light works, but the do light up with driving light, just don't get brighter with brake applied, and without head lights on, do not light up with brake applied.
Thanks,
Joel
   / LK3054xs brake lights not working #2
The wires from the brake switch have become disconnected. Mine hung down under the brake peddle and they get pulled loose on brush. I've reconnected the wires and used wire ties to secure them up under the tractor.
Thanks, took a quick look, they look ok, I'll get a closer look and also test the switch with my meter for continuity. Thanks for the reply, you are right, they are exposed down there, I'll do what you've done for sure.
Thanks again,
Joel
   / LK3054xs brake lights not working #4
Check all the connections for corrosion on the pins. You'll get weird and wonderful things going on with bad grounds or connections.
Steve
Will do, thanks,
Are you referring to the pins (2) on the pedal switch, or another set of pins?
Thanks,
Joel
   / LK3054xs brake lights not working #6
I'd start by checking the bulbs, could be they are blown. It's unusual for both to go at once, but it can happen.
Thanks,
They both work with the driving lights on, but when I push the brake pedal they do not get brighter. Also, when driving lights are off and I push the brake pedal, they do not go on at all. I am hoping its the switch under the brake pedal, will test with volt meter this Saturday.
Thanks again for the posts.
Joel
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
NPK GH-9 Excavator Hammer (A50774)
NPK GH-9 Excavator...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
