LK3054 steering adjustment
   / LK3054 steering adjustment #1
OFarrell
Bronze Member
NH Workmaster 60
My Kioti turns much tighter to the right than to the left. How do I adjust the steering? Is it as simple as pulling the pitman arm and adjusting or is there something else?
   / LK3054 steering adjustment #2
I don't know what would cause that as the tractor has hydrostatic steering; that is, it has no "steering box".The steering is accomplished by hydraulic pressure being applied to the appropriate steering cylinder, either left or right.You could look at the steering cylinders and rods to see if perhaps one of them is bent, more than likely the left:confused:
   / LK3054 steering adjustment #3
I haven't work on a 3054 in over 150 years so it may or may not pertain to your machine.
Check on the inside of the hub and see if you see a bolt with a jam nut on it sticking out that is the bump stop you may have had one side loosen up and that will create your problem.
   / LK3054 steering adjustment #4
Obviously the LK3054 must be well build if Rick's not seen one in the shop for a while (posted by an Lk3054XS TLB owner). PS, Rick, the box blade works great!! Nothing farms rocks better.
Joel
   / LK3054 steering adjustment #5
More than likely means he doesn't sell/hasn't sold many of them ;)
I've got the older style tractor before Kioti switched to hydraulic rams for the steering. This tractor has a hydraulic assist steering box. When I turn the wheel lock to lock neither of the jam bolts make contact. I'll try to get some pictures tomorrow.
   / LK3054 steering adjustment #7
Did this problem just (appear), or has it been ongoing? Either way, after checking for obvious damage to the steering gear(drag link,tie rods,etc) I would count the turns lock to lock, center the wheel between the extremes,pull and reposition the pitman arm;) This doesn't explain how it got out of sync, but gets you back to center:eek:
   / LK3054 steering adjustment #9
Yah, I hear ya. If I read a post relating woes with a 3054, I won't even look at mine when I go into the garage:rolleyes: I just hope someone posts a "happy time" 3054 post before I need to use the tractor:D
It's been like that since I bought the tractor used a few years ago. I'm just now getting around to fixing it. I started with the engine, trans and front axle, now i'm on to steering.
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
40' CONTAINER (A51244)
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
