LK3054 Owners, need a measurement!
   / LK3054 Owners, need a measurement! #1
mathey
Platinum Member
MD
NH TC33D
If you own a LK3054 with R-4 Ind tires, can you tell me the widest dimension (outside of tire to outside of tire?). I need to be able to mow Christmas tree fields. Kioti website says 51.7.
Is it possible to flip the front and rear wheels to dish in?
   / LK3054 Owners, need a measurement! #2
you can mount the rear tires inward to narrow the track. Mine I can. I havent seen the newer model rear wheels. the fronts would be wider if you flipped the rims. they are flat mount so flipping can be done. they are already mounted and look like FWD car rims...deep back offset. I dont think you will have any problems. if the tractor were here I would measure. HTH
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
7022 (A50322)
7022 (A50322)
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
Case IH 8610 Tub Grinder (A50514)
Case IH 8610 Tub...
