lk3054 hydraulic valve block fittings
   / lk3054 hydraulic valve block fittings #1
Jim_in_Omaha
Omaha area
LK3054
I'll post this here since I was not paying attention the first time...
Does anybody know what size the fitting is that needs to go into the hydraulic valve block? I know it's not 16mm. It might be 5/8? There are 3 of them and I'm wanting to replace the ones I got with o-ring to #6 JIC 37's and get rid of the lousy banjo style stuff thats on there now. I keep blowing out seals.
thanks
Jim
I put it in the wrong forum and didn't like it there. I appreciate the input.
I thought maybe someone knew without a doubt which one it is that way I would just order from that site the parts. I already ordered 3 fittings that were wrong and have a $8 shipping bill to eat which is not a big deal, but the wait for the parts to get here is the tough part.
The 3/8 BSPP O.D. is 17.3mm and the banjo fitting I took out was 16.4mm on the micrometer at 1.5 mm threads. I know it may be possible because of a slight amount of play in the fitting when turned part way in. When I get a chance I'll try some of the local hydraulic store later and see if they have any 3/8 BSPP stuff.
Jim
Just for the record,
I did find some 90 degree fittings that work. And they are 3/8 BSPP to 3/8 JIC. They were about 13 bucks each /forums/images/graemlins/shocked.gif
thanks to all for the help
Jim
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
SET OF (4) TITAN MULTI TRAC C/S TIRES & WHEELS (A51244)
SET OF (4) TITAN...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2005 PETERBILT PB335 FUEL & LUBE TRUCK (A51243)
2005 PETERBILT...
