My front wheel had a little wiggle in it. I felt the lug nuts and they were loose. I tried to snug them up by hand, but they just turn. They will not tighten or loosen. So since i just got this thing, the other guy must have ran it loose and stripped the threads.
I ordered studs from messicks for a kubota 2500. Tractor joes and several other sites have the same part number for them as kioti. They were 12mm. Since i need to use the tractor and the wheel is not very loose at all, i decided to check the new lugs and studs against the old before i went to grinding and chiseling to get the wheel off. The new lugs just fit right over the other. Didn't even touch. So i stopped right there and just sent them back. Today i took a lug nut off and miked it. It's 10mm. The stud is 10mm on the front side and 11.7 on the back.
Has anyone ordered new studs?
