Mowing LK3054 finish mower
   / LK3054 finish mower #1
OFarrell
Bronze Member
NH Workmaster 60
Does anyone run wide area finish mowers with these tractors? I would like to pull an 10-12 foot mower. I have been looking at the landpride AFM4211 and Bush hog TD-1100. Any thoughts?
   / LK3054 finish mower #2
Your asking a lot out of that tractor.
You would be running every last little ounce of power that tractor has.
Hope your running fairly level ground
   / LK3054 finish mower #3
I ran a 6' wide First Choice finish mower with mine and it is all it wanted. It did fine but I wouldn't even try anything bigger then that.
   / LK3054 finish mower #4
I can't even begin to see it working out very well . . . and if it does it may just be the slowest mowing job in the history agriculture. I run 7ft. finish mower with my DK45 and all though I can mow in mid range flat out I can tax the tractor if get into some heavy wet stuff and don't lift.
What hp/size tractor should I consider? This is going to be used to cut 10 acres bi-weekly.
   / LK3054 finish mower #6
I think it depends on the mower you are looking at. Do you need a gang of finish mowers for 10 acres? I can't see why you would unless you are cutting something like a park or golf course. Those gang mowers are limited unless you have another small lawn tractor/zero turn type mower for smaller more intimate mowing. Furthermore, they are expensive just for 10 acres. I would save my money and by a large 3pt finish mower and go that route. I have 4.5-5 acres of pasture to cut plus I do my neighbors stuff with either the finish mower or the rotary. One is 7ft. and the other is 6ft. and there is no way a gang mower would work with the exception of my large pasture. I would have it done it about 20 minutes but then what. I spent a large chunk of change on it.
Either way I'd be looking at a 35-40 horse tractor. Are you doing anything else besides mowing?
I've got a 52" Exmark but that's way to slow for 10 acres. I won't be doing anything else on this 10 acre lot but mowing. I'm trying to minimize the amount of time spent on this lot. I did look at 3 point single deck finish mowers but going from a 52" deck to a 72" deck didn't seem like that much of a difference. I would imagine that the tractor puts more hp to the ground than the 52" Exmark.
Mark.r how long does it take you to do 5 acres with the 6 or 7 ft mower?
   / LK3054 finish mower #8
A good rule of thumb for Finish Mowing is 3-4 pto hp per foot of mower width. That number can change up or down depending on conditions, but it is a good place to start.
   / LK3054 finish mower #9
It take me about 3 hours to do it all with the 84" finish mower.
Do you know what the cost of the Landpride gang finish mowers are? At one time I had heard 7k and another time I had heard 12K. I friend of mine had one that he inherited from the owner of the own he purchased along with a NH TC45 or TC55 tractor he never used it but I know his wife sold it CHEAP on craigslist. So cheap I don't think they spoke for a week or so. At the time I didn't have a tractor that could pull or I would have bought it just out of principle.
   / LK3054 finish mower #10
Figure about $1000/ft of width for a BEFCO Flex-Wing Mower.
Electric Forklift Pallet (A50322)
Electric Forklift...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
Radio Tower Antenna (A47384)
Radio Tower...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
Bison NB80 240 3 pt Blade (A50515)
Bison NB80 240 3...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
