lj200 loader?
   / lj200 loader? #1
chrisdvorak
RI
too many
i am buying a tym 233 tractor with loader/backhoe and when i looked at it yesterday at the dealer i noticed that it had a lj200 loader instead of a lt200 loader, the only thing that i noticed that was different is the bucket curl cylinders are black instead of red, is it just a upgraded model with the same lift capacity of the lt200 or should i be worried??:confused:
   / lj200 loader?
nutthin?????
   / lj200 loader? #3
Do both have the quick attach/detach feature on the bucket?
   / lj200 loader? #4
The LJ series loaders have a slightly longer boom and the pivot pin is located a couple inches more to the rear of the tractor. This gives the loader a curve to match better with the hood curve. From what I have seen the specs are the same for both. The quick attach buckets are standard on all TYM loaders. I have it on my t330 and love it.
   / lj200 loader?
thanks for the input, that is what i thought but i just wanted to make sure:)
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
Vermeer BC1800A Wood Chipper (A51573)
Vermeer BC1800A...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
