Live Continuous PTO
   / Live Continuous PTO #1
TEXASHUNTER
I'm about to buy a 5500 two wheel drive.
What is the above and is it any good? Can
you shut the PTO off by a lever or does it
turn all the time on a 5500? Thanks
   / Live Continuous PTO #2
The 5500 2wd has a on off shifter on the pto with a 2 stage clutch. If you don't know what I mean by a 2 stage clutch, the clutch when pushed part way down disengages the tractor drive train, and then when the clutch is pushed the rest of the way down it will disengage the PTO. This allows you to stop the tractor without stopping the operation of your PTO equipment. Thus the term live continous PTO, which has been a system used on tractors for many years, tried & true. Good luck with your 5500, I know you will like it, it is a very solid tractor.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY 14020
585-343-0770
Thanks, so I guess there is no way to shut
off the PTO and keep it from spinning-if you
don't need it?
   / Live Continuous PTO #6
You take the PTO out of gear just like you do the tractor.
Think of it like a 4wd truck. You dont get the front wheels to drive unless you engage the 4wd. When you are done with the 4wd, you disengage the 4wd gearbox from the motor. I you want to run the PTO, you clutch then engage the PTO. If you dont want the PTO, then you leave it in neutral.
It doesnt run all the time, UNLESS you engage it, then you can run it all the time yet still stop and start the tractor using 1/2 the clutch. It is continous because you can leave it run while using the clutch.
That make sense?
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
