Liquid transfer pump
   / Liquid transfer pump #1
Saucymynx
LS MT7 101 Farmall 656 Ford 2610 Farmall 140. JD 670
I’m not sure where this post fits best so I stuck it here. What do you all use for a liquid transfer pump? I need to transfer liquid hay preservative from the storage tank into the tank on my baler. The liquid is more viscous than water but less viscous than oil. It is not really corrosive. It’s a mild acid. I have a hand pump but that is tedious. What do you guys like for a 12 V transfer pump? Thanks.
   / Liquid transfer pump #2
It's been a few years, but I think I used the same 12v pump I sprayed with. As in had a Tee on the inlet side with a hose to go into the bulk tank. I am assuming your applicator uses a 12v pump to spray the preservative. If not, any of the 12v pumps designed for small sprayers like for ATV's would work fine.
   / Liquid transfer pump #3
Agree on a spray pump like a Hypro Shurflo diaphragm pump or equivalent
I see that Dewalt has a new battery powered transfer pump. I think I’m gonna give that a try.
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
