Liquid Ferterlizer
   / Liquid Ferterlizer #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
With the price of ferterlizer going thru the roof, would like to know if anyone has used liquid ferterlizer for their fields/lawns, other than large farms which I know spray. I can purchase 2 1/2 gals of 10-10-10 at Tractor Supply. It states on the label that 14oz will cover 1000 square feet or about 1/2 acre. I can purchase on sale for 19.99 per jug. Any comments on using such a product.
Eddie
   / Liquid Ferterlizer #2
I've used the version with higher nitrogen in my horse paddocks when I didn't feel like getting a ton of granular. It's convenient and seems to do a decent job. I've never bothered to do a soil test to see what difference it made though. My local Tractor Supply has been out of it and I was afraid they had quit carrying it.
   / Liquid Ferterlizer #3
An acre is 43560 square feet, so half of that would be 21780 square feet. 1000 square feet is just a bit over 32' x 32'. I think it may take more than your thinking.
   / Liquid Ferterlizer #4
I buy it in concentrated 2 gallon jugs at the local grainery. Not overly expensice and is mixed pretty lightly. This stuff is a foliage fertilizer, so I doubt it does much for the soil. I user it on our trees in the nursury that look distressed, and our pumkins. works great.:D
   / Liquid Ferterlizer #5
Actually, on most fence and products as such, acreage is considered 210' x 210'. So that would be roughly 44,000 SQ FT. Now divide 210' by 2 and you have 105'. Then 105' x 105' = 11,025 SQ FT. That's how they calculated a half acre. ;)
   / Liquid Ferterlizer #6
PS. Unless your psot wasn't a typo and it truly says 1000 SQ FT and not 10,000 SQ FT, Magis is right, that's not much :eek:
   / Liquid Ferterlizer #7
PS. Unless your post wasn't a typo and it truly says 1000 SQ FT and not 10,000 SQ FT, Magis is right, that's not much :eek:
   / Liquid Ferterlizer #8
For grass, Nitrogen is usually the major requirement. The first number in the fertilizer composition is the % of nitrogen. The liquid fertilizers usually weigh about 10 lbs per gallon. 10-10-10 would contain 1 lb of nitrogen per gallon. Most places, 1 lb of Nitrogen per 1,000 square feet is recommended. 1/2 acre would be roughly 22,000 square feet so 22 gallons would be needed. 22 gallons @ $8 per gallon = $176.00
Check with a local farm supply or feed supplier. Pasture growers usually buy the liquid in bulk. Around here, 30-0-0 sells for about 20 cents per lb. Since it's 3 times as concentrated only about 7gallons would be needed. This stuff weighs 11 lbs per gallon, 7 gallons @ 11 lbs = 77 lbs @.20 per lb = $15.40
Depending on your grass type and weather, you can see the difference in a week. Be ready to mow! Also, you can add weed killer and take care of the weeds with the same application. Weedkillers like 24D are inexpensive.
Check with your local Ag Extension for recommended application rates in your area.
Thanks for the replys. BXpanded, like your idea of putting down straight nitrogen. I went back and figured again. Here is what I came up with. 2 1/2gallon jug = 320 ounces. 14 oz. treats 1000 square feet. 320 divided by 14 = 22.85. 22.85 x 1000 = about 22857 square feet, which is about 1/2 acre. At 19.99 per jug is it cheaper to spray or buy 50 pound bags of 10-10-10 at 17.00 per bag. Trying to save a few bucks.
Eddie
   / Liquid Ferterlizer #10
Just a thought, but here's what I've done to beat the high cost of fertilizer, I have soil samples done, now, instead of trying to match a fertilizer to the soil needs I'm buying straight phosphate, potash and nitrogen and mixing it myself in the spreader, fortunately, I plant 99% clover and use no nitrogen in the fields but I do have a couple of spots I need some on. The larger farm supply stores carry them.
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
78'' skid steer bucket (A53421)
78'' skid steer...
199049 (A51243)
199049 (A51243)
