Limited Hydro Power at 3pt hitch cylinder
   / Limited Hydro Power at 3pt hitch cylinder #1
kawirider00
Bridgeton,NJ
Belarus 310 Farmall H
ok i have a belarus 310 tractor and here are my symptoms, the 3pth uses a cylinder to lift its arms, the cylinder is in good working order as i have pressure tested it in a press and it doesnt leak or move, the rear lift arms can barely lift a 250lb back blade, and if i throttle up the tractor there is more lifting power, the hydro lever will not release itself either in the up position, but in the downward position it will and seems to have more pressure in that position;. OK now for the part that will probly solve this for you, if i get the blade all the way up, and release the lever, it will stay in up position, add a 200lb person and put the lever into lift position and the arms will drift downward and the lever wont stay in the lift position, My repair manual says that i may have to clean something in the valve body of the tractor of course it is burried, and have not to much of a clue as what to do, any help is appreciated
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2011 EDMONTON TRAILER MFG FRAC PUMP (A53843)
2011 EDMONTON...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2019 FORD F150XLT (A53843)
2019 FORD F150XLT...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
