Like Electric UTV for quiet; but I want power steering
   / Like Electric UTV for quiet; but I want power steering #1
kokosnood
Kubota HST 2800 xtra power
Hello friends,
I almost purchased a brand new Polaris EV recently; but I realized that where I'm going to drive it I really need power steering. The Polaris salesman said it wasn't an option and it couldn't really be added on.
Does anyone recommend an Electric UTV for ranch work that has power steering as an option?
Stefan
   / Like Electric UTV for quiet; but I want power steering #2
I used EV vehicles supplied maintenance crews for years and none had PS. They were on pavement and had hard solid rubber tires. For off pavement use, I would not want a non-PS UTV regardless if it was gas/diesel/electric, that is why I bought the RTV900. A work UTV should have PS while a sport UTV can get away without PS.
   / Like Electric UTV for quiet; but I want power steering #3
I would take the QUIET over power steering ANY day! MOST UTVs are just horribly LOUD! With the E-Gator, the only time it becomes a problem is if you have something (possibly a drink) in one hand.
I agree!
   / Like Electric UTV for quiet; but I want power steering #5
It maybe a tall order to find an electric UTV with Power Steering.
My guess the PS system will draw to much amperage from the batteries?
Good luck!
   / Like Electric UTV for quiet; but I want power steering #6
Hello friends,
Stefan
It's strange that they can't do power steering on one since the power steering is electrically powered. I wonder if a universal EPS would fit? SuperATV offers a universal model.
Good luck!
That's what the dealer told me...Power Steering would take too much of the power needed for the motor
   / Like Electric UTV for quiet; but I want power steering #8
I don’t believe a universal EPS system will work. EV’s have a 48 volt system, whereas UTV’s are 12 volt.
If a 48 volt EPS was available, the amperage draw would kill the batteries rather quickly.
Example a 200 watt EPS motor would draw around 4 amps with 48volt system.
The OP would be best served trying a steering wheel spinner knob.
   / Like Electric UTV for quiet; but I want power steering #9
I don't think it would kill the batteries quickly. BUT, it would certainly reduce the operating time which for most of these machines is limited to start with.
48 to 12 volt converters are available in a variety of current ratings. I bought one to run my VHF radio. I don't know about Polaris, but all Golf Carts and the E-Gator, DO NOT HAVE A NEGATIVE GROUND. That created issues for my radio. The aftermarket power steering is probably negative ground too!
   / Like Electric UTV for quiet; but I want power steering #10
I respectfully disagree given the estimated 4 amps is basically at no load.
If a 48/12 converter is used you can expect at least 16 amp draw on a 200 watt motor.
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2004 Sterling Acterra Truck Cab & Chassis S/A (A51692)
2004 Sterling...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2019 Kubota RTVX1140 (A50121)
2019 Kubota...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
