Lights
   / Lights #1
Ford4600
Ford 4600
My ford 4600 has no lights was wondering if I have to remove the fuel tank cover? And which switch is the lights the sliver or yellow one I know the red is the fuel shut off
Mike
   / Lights #2
i sure wouldn't remove the cover just to add a set of lamps.
suggest you trace the wires. never know what's happened since the late 70's.. might have custom wireing done on it!
   / Lights
Sorry I meant the lights aren't working and wondering if I had get behind the cover to see if a wire is off or broken they were working last winter
   / Lights #4
check power tot he elements. if ya got power.. check ground or the lamp bulbs.
if no power. pull and check fuse in switch and / or supply line.
can do it with cowl in place.
soundguy
   / Lights #5
I installed headlamps on my 5000 this weekend. We were able to remove the switch from below. The wiring all looks to be original. The wire leading to the headlamps is yellow. Hope this helps.
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
