Loader Lights
   / Lights #1
Boit
Here's what I've learned lately. After acquiring 26 acres from my grandparent's estate that has about 8 acres of grass and the rest under pines and various hadwoods, I needed a tractor that can WORK. So, I bought a '07 Mahindra 3215HST with a FEL and backhoe combo(shipped from Georgia). My experience is as follows. Not a bad tractor. Complaints: Hydraulics leak(not only outer leaks, but leaks via the controls so that you can't rely on keeping your implements elevated). Headlight bulbs can't be replaced(you must buy a bulb/socket/wiring harness combo at extremely high prices just to get your lights working again...can't just buy a bulb(Very cheesey!!!). My fix was simple. Went to the local auto parts store and bought a set of 12v(work) lights. Made my own harness and wired them into the factory switch. Mounted them on the front of the hood and is better than factory design. My lights are now higher than factory which is an improvement. I can see better.
   / Lights #2
You mean to tell us the tractor is only four years old and it leaks?
I would get rid of it.
   / Lights #3
That's normal with most hydraulic systems, when the equipment is not running (which is what I hope you are referring to). You shouldn't rely on keeping an implement elevated when shut down.
JB
   / Lights #4
I didn't mean to harsh...
My systems (FEL and 3pth) don't move much at all and I cant belive a unit a few years old has leaks already. Maybe the dealer will cover some of the work needed to eliminate the leaks.
2008 BMW 535xi AWD Sedan (A46684)
2008 BMW 535xi AWD...
2018 FORD TRANSIT 250 VAN (A45678)
2018 FORD TRANSIT...
2015 Toyota Prius C Hatchback (A46684)
2015 Toyota Prius...
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
Kubota V3800T Diesel Engine (A49251)
Kubota V3800T...
2023 Chevrolet Tahoe SUV (A48082)
2023 Chevrolet...
