Lights on 850
   / Lights on 850 #1
thomasalva
JD 850, MF 35
I recently acquired an 850 and I've been getting everything sorted out, but I'm not sure what to expect as far as how the lights are supposed to work. The headlight bulbs were both obviously burned out, so I've replaced them, but still no headlights.
The dash switch is labeled Off, F, W, H1 and H2. I would assume H1 and H2 are the low and high beam headlights, but I'm not sure about the F and W. The wiring looks pretty decent and I've checked fuses, etc., so I'm suspecting the switch might be bad. When I switch to F, H1, or H2, the red hazard/blinker light on the left rear fender comes on. None of the other lights have worked so far, including the little red ones on the dash (bulbs may be burned out, but I haven't checked those yet).
It looks like the wiring harness from the headlights goes to the alternator (two white wires), so I had wondered if the lights are supposed to be on all the time when the tractor's running.
Also, I would like to know the function of the rear lights. There are two lights on each fender. The two forward lights (orange lens) seem to be the same type, the rear light on the left (red lens) blinks as I mentioned, and the right rear light (metal case, lens is missing) looks like maybe a work light. I guess that the two orange lights would be the left and right turn signals, and the red light brakes, but I'm not sure about that.
   / Lights on 850 #2
F=Field
W=warning(amber flashers)
   / Lights on 850
Ok, thanks. So is H1 and H2 for headlights? The John Deere parts diagram calls the switch a "turn signal controller".
   / Lights on 850
I just found a post that describes this for the 950, so I assume it's the same on the 850.
2017 Isuzu NRR Box Truck (A51692)
2017 Isuzu NRR Box...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53473)
Gooseneck...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2016 Great Dane 102"x48' Step Deck (A50123)
2016 Great Dane...
